Ball Joint Gasket Question
Paranyos
First Name: Paul
Last Name: Aranyos
Post by Paranyos » Sun May 19, 2019 3:10 pm
Does anyone have a guess as to why my 27 touring would have 3 ball joint gaskets between the pan and ball cap? This has me puzzled!
A man has got to know his limitations!
Re: Ball Joint Gasket Question
Post by Scott_Conger » Sun May 19, 2019 3:11 pm
I'm puzzled, too. What is a ball joint gasket?
Paranyos
First Name: Paul
Last Name: Aranyos
Post by Paranyos » Sun May 19, 2019 3:25 pm
That is what Snyders calls it in their catalog. It is the gasket between the back of the pan and the ball cap. The point where the U-joint matches up with the transmission. Round gasket with 4 holes for the bolts.
Post by DanTreace » Sun May 19, 2019 3:53 pm
Should be only one gasket on the 4th main surface against the crankcase/hogshead to prevent oil leaking at that joint.
Only can guess a former owner had loose fitting torque tube ball and figured it would be snugger with more gaskets? That isn't the way, if the torque tube ball is worn, you are best served by using the accessory shims, that fit around the torque tube ball and held by the U-joint ball cap, and take up that excess play of a worn ball.
IMG_0653 (800x600) (550x413).jpg (113.63 KiB) Viewed 4945 times
No gasket between the U-joint ball cap and the 4th main.
got10carz
Last Name: Meixner
Post by got10carz » Sun May 19, 2019 4:03 pm
My thought is the oil pan isn't located properly, and the gaskets acted as shims to push the ball cap backwards. The centering flange would be about 3 gaskets wide.
Paranyos
First Name: Paul
Last Name: Aranyos
Post by Paranyos » Sun May 19, 2019 4:44 pm
It does have the round soft metal shim around the ball also. I just cant figure out the reasoning for 3 gaskets. My fear is that there is a problem that he was trying to compensate for. I am just not sure what that would be or how to identify it.
Post by RajoRacer » Sun May 19, 2019 5:07 pm
Simple test to check for wear in the ball cap area is to pull the hand brake lever back & forth rather quickly several times in succession from the forward position to engage the clutch throw-out bolt and watch the ball end to see if it is actually 'walking" in & out of the collar - if so, install the shaped metal shim mentioned above.
Last Name: Juhl
Post by Oldav8tor » Sun May 19, 2019 7:20 pm
I would think additional gaskets would loosen the ball cap, not tighten it. Since I will soon be installing mine to my engine, I have a question: Is it best to use a dry paper gasket in this location or could I forego the gasket and just apply a bead of ultra black RTV?
Post by RajoRacer » Sun May 19, 2019 7:24 pm
I use both - paper gasket & a small bead of black RTV on both sides.
