This came in with some KRW stuff. But don’t think it is anything to do with KRW. Looks like some kind of governor, inside are springs that push against the counter weights.
Any ideas?? Thanks Dan
What is this?
John Codman
- Last Name: Codman
Re: What is this?
My guess is that it is part of a governor. Those look like flyweights, and I'm thinking that it is driven by the gear, and the weights control the speed of the shaft with the double disks. Somebody will probably come up with an obvious better answer and I'll have to beat myself with a wet towel.
- Last Name: Tannehill
- Board Member Since: 2002
Re: What is this?
Weren’t there some distributors made that way?
Re: What is this?
Some type of governor or distributor shaft for a 30’s era car or close to that time frame. Another one of those parts you might find in a trailer load of parts and pieces you might see at a swap meet.
