This is an original Sure Feed Oiling System for the model T. It can used with the two different ways to drain the oil from the hogs head cover into the front of the pan. It has the original fitting that bolts to the pan to engine bolts and drains the oil through one of the bolts that would hold the pan to the engine. The way that I used this until I went to a full pressure system, was a fitting that was bolted into the side of the pan. A drilled hole with a fitting that drained the oil into the front of the pan. $100.00 plus the postage.
Tom five03-644-937four twoelliott@msn.com
Sure Feed Oiling System For Sale Sold
elliott1936
Topic author - Posts: 373
- First Name: Tom
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1921 Speedster 1927 speedster
- Board Member Since: 2013
elliott1936
- First Name: Tom
Re: Sure Feed Oiling System For Sale
Repost this item for sale
elliott1936
- First Name: Tom
If you can use this item I will take an offer. Tom
South Park Zephyr
- Last Name: Francis
- * REQUIRED* Type and Year of Model Ts owned: 25 RPU, 27 Roadster
- Board Member Since: 2022
Email sent
South Park Zephyr
Check is in the mail
Thanks,
Scott
Thanks,
Scott
