Carburetor cleaning video with a twist
Gen3AntiqueAuto
Topic author - Posts: 415
- Last Name: Foye
- * REQUIRED* Type and Year of Model Ts owned: 27 Fordor, 15 speedster (2), 23 touring, 26 fordor, 25 TT
I'm running experiments on how to clean Model T carb's here for anyone interested. I have one L-4 ready to be re-assembled (on camera of course) and that will be offered up for sale when it's back in one piece. If you're curious about different methods I did a 3 way "race" and compare the results here: https://youtu.be/lWZf0p9M6UE
If you want to help me with this task of passing on restoration and Model T knowledge to the next generation, I could use more subscribers and views. "likes" also help as they prompt youtube to push the videos on a wider audience. When I get to 10,000 subs I will try once again with giveaways. Tried it in the past but there was no interest.
mbowen
- First Name: Miles
- Last Name: Bowen
Re: Carburetor cleaning video with a twist
From the videos I’ve seen on Evaporust, it seems to work well on iron and steel. Check out Keith Rucker’s Vintage Machinery YouTube channel.
Miles
1924 Touring “Bonnie”
1925 Express Wagon “Clyde”
mbowen
- First Name: Miles
- Last Name: Bowen
Probably not.speedytinc wrote: ↑Fri Sep 22, 2023 10:34 pmIs it going to get thru the varnish of a clogged idle circuit?
Miles
tom_strickling
- First Name: Tom
- Last Name: Strickling
- * REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
Use a sand blaster on most parts. NOT the float of course.
“The trouble with retirement is that you never get a day off.” – Abe Lemons.
jsaylor
- Last Name: Saylor
I have used an Ulta-Sonic Cleaner from Harbor Freight and Simple Green with good results.
Gen3AntiqueAuto
- Last Name: Foye
That is on my to-do list - I think they make a sassafras flavored one now!
