WTB 6 volt ignition coil for distributor
Bryce S.
First Name: Bryce
Last Name: S
Post by Bryce S. » Sat Sep 23, 2023 5:05 pm
Does anyone have any 6 volt Texas T black ones or any 6 volt blue bosch ones? I'd prefer to support a forum member than order from big store like Amazon and such.
Thanks,
Bryce S.
Bryce S.
First Name: Bryce
Last Name: S
Re: WTB 6 volt ignition coil for distributor
Post by Bryce S. » Sun Sep 24, 2023 10:37 am
Surely someone has one?
Post by TRDxB2 » Sun Sep 24, 2023 11:14 am
Question: How did you mount the coil - up, down sideways. Oil filled should be mounted upright
Alternatives
Product Description
The Bosch 6 Volt, 1.5 Ohm VW Ignition Coil comes with a mounting bracket. The Bosch coil is epoxy-filled and will not leak if mounted sideways or upside down. We almost exclusively use Bosch ignition components in our VWs and recommend only Bosch ignition parts in your car. The coil fits 1954 through 1966 Standard Beetles, 1956 through 1966 Karmann Ghias, 1955 through 1966 Type 2 Bus models and 1962 through 1966 Type 3s. This part is also listed under P/N 9408.
So it sounds like you might be happy with 6 Volt, 1.5 Ohm epoxy-filled ignition coil https://www.google.com/search?q=6v+epox ... roducts-cc. Autozone $15.99 https://www.autozone.com/ignition-tune- ... lsrc=aw.ds worth a try - almost the price of having one shipped to you
Bryce S.
First Name: Bryce
Last Name: S
Post by Bryce S. » Sun Sep 24, 2023 5:34 pm
Alternatives
Product Description
Thank you for the reply. I do in fact have it mounted upright. I even have it towards the driver side of the firewall so it's away from the hot exhaust manifold. Will 1.5 Ohm of resistance be enough? For some reason I thought the preferred amount was 2 to 3.5? I'm not entirely sure.
Post by TRDxB2 » Sun Sep 24, 2023 9:35 pm
They always say to use the recommended coil - whatever that is - since Texas T has no specs'. Also look at their offerings. The "blue" coil is the same part number as the black one. The "Flame Thrower" coil may be the PerTronix 12v Flame-Thrower Coil - 3.0 Ohm - 40000 Volt (they make both an oi filled or epoxy filled ones). Voltage is what produces spark. My guess is that they all produce 40K volts hard to tell not everyone includes any specs, except for some high performance engines.
Remember the equation Voltage = Current x Resistance So 6v= 4amps x 1.5 ohms & 12v = 4amps x 3ohms
The reference to 2 -3 ohms would be applicable to 12v coils.
I'd go with the Duralast coil & if that didn't wasn't satisfactory then one that spec'ed 6v, 1.5ohm & 40Kvolts. Oil Filled is usually less expensive for upright mounting. Epoxy filled if you anted to mount it horizontally or upside down.
