WTB window regulator
Tinner12
Topic author - Posts: 161
- First Name: Vernon
- Last Name: Enis
- * REQUIRED* Type and Year of Model Ts owned: 1917 and 1924 touring,1926 4 door
- Board Member Since: 2011
I need a window regulator for my 1926 fordor. Right rear door.( right description Alan} Someone installed a right side in the door so I have a extra right regulator.Will other years work ??Let me know price and shipping to Nwport Wa
jab35
- Last Name: Bartsch
Re: WTB window regulator
Vernon: There's some info in this post. https://www.mtfca.com/discus/messages/1 ... 26863.html
I looked at some other posts that suggested modified Model A regulators could be made to work. Model A probably means a call to Snyders, who are usually very helpful. Good luck, jb
Looks like more info may be needed.
Confused : If they installed a right side in the door why do you need a right if you have an extra right regulator?
NOTE that a Front Left & Rear Right are same part numbers regardless of the color of the upholstery. Year doesn't matter but wood vs steel door does
- Attachments
- regulators.png (251.55 KiB) Viewed 895 times
Tinner12
- Last Name: Enis
my mistake. I have two left side regulators. Need a right side rear door.
No confusion there Vernon. You have it right/correct!!!!
