For sale: brass era speedometer
Nate22huckster
First Name: Nathan
Last Name: Fahrni
* REQUIRED* Type and Year of Model Ts owned: 1922 huckster, 1925 tudor, 1926 TT dump truck, 1927 tudor
Post by Nate22huckster » Sun Sep 24, 2023 10:43 am
Stewart model 100 speedometer for sale. I bought this at a swap meet 12-15 years ago with the intent on using it for my huckster I was planning to build, well, the huckster ended up being a 1922 so I didn’t end up using this brass era speedometer. It will need fully restored but is in pretty decent shape. Inside looks very nice and I don’t see any cracking in the pot metal pieces and the numbers are clean and in good shape. The brass bezel had three hairline cracks in it and I sent it out and had them repaired with silver solder, you shouldn’t even notice them after polishing the brass. I set the odometer to zero because it was simple to do. The input shaft turns but is pretty stiff so it’ll need freed up. Otherwise I’m not sure what else would need done internally, I’m no expert on these. The item will be sold as is and I’m asking $170 (shipping is included in the price). Thank you.
