Wheel to Rim bolts
Jed
First Name: Jed
Last Name: Welsh
* REQUIRED* Type and Year of Model Ts owned: 1920 Roadster pick-up
Wheel to Rim bolts
Post by Jed » Mon May 20, 2019 5:36 pm
how tight should we tighten the four bolts that attach the rim to the wheel?
Last Name: Strange
Re: Wheel to Rim bolts
Post by CudaMan » Mon May 20, 2019 5:45 pm
30 foot pounds would be a good start, IMO. There is no need to graunch down on them so hard that the lug tabs are pulled down into contact with the wheel felloe. :)
Jed
First Name: Jed
Last Name: Welsh
Post by Jed » Mon May 20, 2019 6:00 pm
Thank you Mark.
Jed
Post by Allan » Mon May 20, 2019 6:41 pm
Unless the felloe and/or the rim have been worn where they engage, the lugs should never fit up to the felloe. I tighten each nut in turn, a little at a time, adjusting the runout in the rim as I go. They need to be tight, but not overdone. I check them after use to make sure they are set. After that, treat them as you would your modern car.
Hope this helps.
