Wanted: Side and tail lights
Philip Lawrence
First Name: Philip
Last Name: Lawrence
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1917 Runabout, 1919 Touring
Board Member Since: 2014
Post by Philip Lawrence » Sun Oct 01, 2023 11:36 pm
I'm looking for a nice set of side lights and also a nice tail light for a 1916. These would have steel rims and have the small vent holes around the base of the chimney. The reflector inside is round unlike the later lights that have a more square shaped reflector.
Re: Wanted: Side and tail lights
Post by Allan » Mon Oct 02, 2023 7:39 am
Philip, on our Canadian sourced cars, the round "diver's helmet" reflectors are satin nickel plated brass. The tops and the lens rims are also brass. These are typical of 1915 lights. By 1916 the lamps were all steel, with the squared off steel reflector. These are much easier to find.
CTLeonard
Last Name: Leonard
Post by CTLeonard » Tue Oct 03, 2023 12:37 pm
I have a nice set of E&J 32 sidelights fs. ctleonard64@gmail.com
Philip Lawrence
First Name: Philip
Last Name: Lawrence
Post by Philip Lawrence » Tue Oct 03, 2023 1:02 pm
Allen, Thank you for your comment. I wish the kerosene lamps here had reflectors made of brass, U.S. production used steel reflectors. It's hard to find them without heavy rust and pitting these days. I think the square type reflectors came along about 1919 in the U.S. The reflectors I believe were zinc plated.
