Where does this go???
Marty Bufalini
First Name: Marty
Last Name: Bufalini
Post by Marty Bufalini » Mon May 20, 2019 7:17 pm
Where does this mount? On the front seat kick panel?
Thanks in advance.
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: Where does this go???
Post by Humblej » Mon May 20, 2019 7:46 pm
It mounts along the passenger front door pillar for the 26-27 fire wall mounted fuel tank.
Last Name: House
Post by George House » Mon May 20, 2019 7:56 pm
I’ve never seen one but judging by the ad “ for late model Fords with the gas tank under the hood” leads me to believe it connects to the ‘New and Improved’ sediment bulb. If so, I’d think this accessory would be fairly unnecessary because it’s easy to lift the gas filler lid, unscrew the gas cap and get the wood gauge out to check gas level. Now the earlier Model T s with gas tanks under the seat requires your lady to get out and you wrestle the seat springs to check the gas. That gas sight gauge accessory of the era that’s still being reproduced today makes a lot more sense.
Post by Mark Gregush » Mon May 20, 2019 8:03 pm
People wanted convenience just as much back then as now! You could sit in your seat and see that you were getting the gas you payed for.
Last Name: House
Post by George House » Mon May 20, 2019 8:07 pm
So, “if you could sit in your seat” in a Ford with the gas tank under the hood......Where Does This Go ??! Mark??
Gary Gregory
First Name: Gary
Last Name: Gregory
* REQUIRED* Type and Year of Model Ts owned: 1927 Model T Roadster
Post by Gary Gregory » Mon May 20, 2019 8:34 pm
I had one on my 27 Roadster. It was attached on the passenger side pillar where the kick panel attaches. And yes you can see it from the seat.
First Name: Jeff
Last Name: Humble
Post by Humblej » Mon May 20, 2019 9:06 pm
Similar device
Post by Rich Eagle » Tue May 21, 2019 12:31 pm
Marty Bufalini
First Name: Marty
Last Name: Bufalini
Post by Marty Bufalini » Tue May 21, 2019 6:40 pm
So, this wouldn't work on my 1914?
First Name: Jeff
Last Name: Humble
Post by Humblej » Tue May 21, 2019 7:30 pm
No Marty, its for a 26-27 improved Ford.
jsaylor
Last Name: Saylor
Post by jsaylor » Wed May 22, 2019 12:33 pm
Similar to this one in my 27 Tudor.
gas guage.JPG (87.36 KiB) Viewed 5519 times
Last Name: House
Post by George House » Wed May 22, 2019 3:21 pm
OK, I’m a visual kinda guy and now I see where that accessory gas gauge is planted. But how is it integrated into that ‘upside down question mark’ New and Improved gas line ? I wrongly assumed it fastened to the sediment bulb.
