Looking for
Topic author - Posts: 3859
- First Name: Tom
- Last Name: Rootlieb
Looking for
2 rear wheel hubs with small brake drums. 12 hub bolts and nuts. 1pr. early front fender irons. 1pr. 26-27 spindles. 1 straight spindle arm. 1 set 09-10 hud caps. Early front motor mount. Bottom leaf for rear spring. Rear spring u bolt set. Early no hump spool. Thanks.
Tim D
- Last Name: Dickson
- * REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
Re: Looking for
I have a couple straight arms.
Re: Looking for
I have the hub bolts & nut (new & used), straight spindle arm, several early front motor mounts complete & rear spring u bolts.Dollisdad wrote: ↑Sat Oct 07, 2023 8:33 am2 rear wheel hubs with small brake drums. 12 hub bolts and nuts. 1pr. early front fender irons. 1pr. 26-27 spindles. 1 straight spindle arm. 1 set 09-10 hud caps. Early front motor mount. Bottom leaf for rear spring. Rear spring u bolt set. Early no hump spool. Thanks.
May have hub caps can't remember year. Will send PM with pictures later this afternoon
I posted a FS for the motor mount recently viewtopic.php?f=5&t=39023 (subtract shipping from these and will ship all for free
Re: Looking for
Took pictures of 2 early motor mounts, spindle arm, rear u bolts, hub bolts need to downsize to send PM or you can email me & I can send that way, would be better. Can't remember - Is the one on the left an early no hump?Dollisdad wrote: ↑Sat Oct 07, 2023 8:33 am2 rear wheel hubs with small brake drums. 12 hub bolts and nuts. 1pr. early front fender irons. 1pr. 26-27 spindles. 1 straight spindle arm. 1 set 09-10 hud caps. Early front motor mount. Bottom leaf for rear spring. Rear spring u bolt set. Early no hump spool. Thanks.
- Attachments
- T191 -T191B.png (303.63 KiB) Viewed 927 times
Joe Bell
- First Name: Joe
- Last Name: Bell
Re: Looking for
I may have the fender irons for the forked lights but no eyelet ones for top strap?
