Free: 4 pcs. cut down remains of running board brackets removed from a 1911-1912 frame. These are the real early ones with the forge lines on the sides. These are too good to just throw away; if you have the rest of the bracket just missing this end, and you're really good at TIG welding, you're in luck. Free if you pay shipping. Thanks for looking.
Free: Pieces of Early Running Board Brackets
Rodger Erickson
Topic author - Posts: 492
- First Name: Rodger
- Last Name: Erickson
- * REQUIRED* Type and Year of Model Ts owned: 1920 Speedster
Re: Free: Pieces of Early Running Board Brackets
Well spotted Roger. These illustrate the difference in cross section to the later type. Clearly these are more pear shaped rather then the usual more asymmetrical shape of the later ones.
