Generator Housing Hole
ClockDoc
Last Name: Grabowski
* REQUIRED* Type and Year of Model Ts owned: 1924 Fordor
Post by ClockDoc » Tue May 21, 2019 11:57 pm
What are the threaded holes for? There is 1 hole by each field shoe screw.[image]
[/image]
I watched the Model T Tips video on Generator rebuilding, but these are not mentioned.
Any ideas?
Re: Generator Housing Hole
Post by Mark Gregush » Wed May 22, 2019 1:04 am
There would only be the two holes to mount the cutout on top. (don't use too long of screws as they can short out the field windings if too long) If there is one hole has each pole screw(4) they do not belong there. Will not hurt anything. Maybe someone repurposed the generator at some point in its life.
ClockDoc
Post by ClockDoc » Wed May 22, 2019 8:47 am
Thank you Mark, I feel kind of dumb now because I forgot about removing the cut out from that generator.
Question answered, problem solved, what a great forum.
Post by Mark Gregush » Wed May 22, 2019 12:27 pm
We all have our duh moments. ;)
