Axle housing
JohnM
Topic author - Posts: 752
- Last Name: Michaelree
- Board Member Since: 2010
Axle housing
I regularly inspect my 26 touring before a drive, I have cleaned the undercarriage and an area on the rear axle appears to continue to get oily. Is it possible that the housing is cracked? I would like to avoid a catastrophic failure.
Re: Axle housing
Clean it up with solvent and then some paint remover in the suspected area. Drive it a while and you probably can see specifically where the leak is from and maybe a suspected crack. If not it’s probably leaking where it’s riveted together.
SurfCityGene
- First Name: Gene
- Last Name: Carrothers
Re: Axle housing
Many times it can be very difficult to see where oil is leaking from on a shiny black surface.
I've heard baby powder, talc or flour applied to the surface suspected of leaking will easily show where a leak is coming from?
1912 Torpedo Roadster
Re: Axle housing
Be sure it's not related to moisture or oil vapor from the exhaust. Sometimes riveted joints will slowly seep oil. It usually doesn't indicate a problem, but I'd want to look carefully for any indication of movement between the riveted parts. Cleaning up the area as suggested above, then taking a drive on a dirt road might help pinpoint the leakage. If the joint is mechanically tight, thoroughly cleaning the area and then painting it might stop the leakage.* I'd also check the radius rods for any sign of looseness or misalignment. Excess lubricant in the axle might cause a leak.
JohnM
Re: Axle housing
Thanks all for your thoughts. The oil level is correct, the exhaust pipe extends past the axle. As suggested I'm going to thoroughly clean the area and inspect with a magnifying glass. If it is just seeping at the joint and or rivets, that is not a big concern. My biggest fear is if the housing is cracked, to have it break and separate while driving.
Re: Axle housing
Its quite common to see a ring of dried grease & oil @ the joint of the tube & casting. They weeped from day one.
Be glad you dont have a massive leak as found in many 13-14 housings.
Casting failure would be rare. Go ahead & look for your peace of mind. I have not seen cracks or flaws on the scores of housings I have encountered.
This is another part of a model T that was not designed to be leak free.
JohnM
Re: Axle housing
Thank you John, that is just the answer I was hoping for.
