Champion 30 brass top plugs
Roger Byrne
First Name: Roger
Last Name: Byrne
* REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo Open Runabout, 1914 Touring, 1921 Coupe, 1912 Speedster (in progress) 1927 Touring
Post by Roger Byrne » Wed Oct 25, 2023 10:10 pm
Is anybody running Champion 30 Brass Top plugs in their cars? How are they working out?
Preserving Mechanical History for Future Generations since 1965
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: Champion 30 brass top plugs
Post by Humblej » Thu Oct 26, 2023 10:00 am
Never saw a Champion 30 before, please post a picture.
Roger Byrne
First Name: Roger
Last Name: Byrne
Post by Roger Byrne » Thu Oct 26, 2023 10:53 am
Here is what they look like. The same as the regular T plug but a bit shorter.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Thu Oct 26, 2023 11:36 am
Not for T. That doesn't appear to be a pipe thread, and the plug washer included indicates the plug is intended to be run down on it to the shoulder on the hex.
Get a horse !
Roger Byrne
First Name: Roger
Last Name: Byrne
Post by Roger Byrne » Thu Oct 26, 2023 12:44 pm
Rich, at first that is what I was thinking. However it is the standard tapered pipe thread and mic's with the same taper on the top and bottom of the threads as the standard T plug. It is not undercut above the threads so I can't see how that ring would ever seat. When installed in the head, it tightens at the same depth as a regular T plug and compared to the standard X body which protrudes into the combustion chamber about 1/4 inch, this plug body extends only about 1/16". The electrode does extend passed the body (see photo) so it is well into the combustion chamber.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Thu Oct 26, 2023 12:52 pm
That's interesting, Roger ! Thanks for explaining. With a pipe thread, should work in a T, the only sensitive issue being the amount it intrudes into the combustion chamber. Guve them a try and let us know ! 🤔
Useless factoid for the day - the small one-lung gas engine Maytag provided to power their early square tub grey machines in the model T era also used a Champion plug with a 1/2" pipe thread. When these were still around, I remember seeing them running a model T champion "X" plug ! I doubt if many Ts ever ran on the Maytag plug ! But it could have been done ! :lol:
Get a horse !
