Model T Electrical Schematics Available
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Mon Jan 14, 2019 4:05 pm
The MTFCI Tech Info section has some new simplified Model T wiring Schematics in color.
Check them out
https://nebula.wsimg.com/5ccce9540b807f ... oworigin=1
Respectfully Submitted,
Be_Zero_Be
Jim_PTC_GA
Last Name: Fisher
* REQUIRED* Type and Year of Model Ts owned: 1924, 1925-ish
Re: Model T Electrical Schematics Available
Post by Jim_PTC_GA » Mon Jan 14, 2019 4:24 pm
Very nice, I like this set of drawings very much. Now I just need to upgrade to color printer.
Just give me time to Rust and I'll be good as new. :) Wabi-Sabi
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Mon Jan 14, 2019 6:40 pm
Thanks Bob! Very nice and they brought up a question I had in my noggin' about the wiring harness that came with my 18. PO's thought it was a 22.
Post by Original Smith » Wed Jan 16, 2019 11:10 am
I'm not electrical oriented at all, so here's my question. This would be for a 1922 with no starter, and the switch still mounted on the coil box. I don't see any need for the choke coil? Am I correct?
Post by Rich Eagle » Wed Jan 16, 2019 11:20 am
Those are very nice. I recall a friend bringing his T over with wiring problems. He he had installed a new terminal block and it wouldn't start without the lights on. We got out the Service manual but neither of us had good enough eyes to read the fine print.
Thanks Bob and MTFIC.
Post by Mark Gregush » Wed Jan 16, 2019 11:30 am
The 22 cars would not have had the switch on the coil box and (up to 1926) with no starter/generator would have come with the choke coil mounted behind a blank off on the instrument panel (in place of the ampere meter)as it would still be using mag powered lights.
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Wed Jan 16, 2019 2:32 pm
Bob has done a great job here.
I love his comment on the first page "... for every absolute fact there are at least three exceptions." :D How true!
Looking at the diagrams in 'order' it is interesting to see 'technology' advance and become more complicated at every step. The 'first' diagram vs the 'last' is quite a change - all step by step.
Thanks to Bob Cascica for this.
Adrian Whiteman
richc
First Name: Rich
Last Name: Chillingworth
* REQUIRED* Type and Year of Model Ts owned: 1924 C-Cab TT
Post by richc » Wed Jan 16, 2019 3:55 pm
Would the later non-starter car, those with the firewall terminal block, have an electric tail light as shown in drawing #3? Or would it just be the oil tail lamp?
Rich C.
Post by DanTreace » Wed Jan 16, 2019 4:56 pm
Rich C.
As noted by Bob:
After 1916 there are overlaps and many exceptions as to which drawing applies to what year and what model.
As everyone in the Model T community knows - for every absolute fact there are at least three exceptions.
An oil tail lamp would be supplied with non-starter open T's, as there is no storage battery. But in the later years, when the T was around a while, many owners installed storage batteries, so even Ford knew that. The terminal block shown is the 4 lug, and the left side was reserved for BAT, in case an owner installed a battery. This terminal block is for the steel dash, '23-'27 open car non-starter.
1926 runabout, non-electric, would have magneto head lamps, and you can see the oil tail lamp. And non-demountable clincher wheels ;)
Open car / bare chassis, non-starter terminal block for steel firewall
John Warren
Last Name: Warren
Post by John Warren » Thu Jan 17, 2019 8:55 am
Bob, Great work! Would you also consider doing the coil box mounted ign... BATT/MAG wiring in side the box. Thanks for the wonderful diagrams.
