Piston material
tdump
First Name: Mack
Last Name: Cole
Piston material
Post by tdump » Thu Nov 09, 2023 8:12 pm
This is slightly off topic but i know alot of T folks use aluminum pistons.
These russian guys make copper,bronze,brass and aluminum pistons and put them in a 4 cylinder engine and run it way to hard,the copper except for the wrist pin,held up the best.
https://www.youtube.com/watch?v=RLWSljLIBaw
Re: Piston material
Post by TXGOAT2 » Thu Nov 09, 2023 8:40 pm
I've never seen any pistons in IC engines that weren't high grade cast iron, or "piston steel", a kind of semi-steel, or some aluminum alloy or other. I've seen bronze crossheads, and babbit-lined steel or cast iron crossheads. Some pistons have tin plated skirts, and some appear to have steel heads and ring lands with some kind of alloy skirt. (Pontiac) Forged aluminum pistons have advantages, but most are cast.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Piston material
Post by Kevin Pharis » Thu Nov 09, 2023 11:51 pm
Cast aluminum automotive pistons are typically “hyper eutectic” aluminum alloys, or extremely high silica content. Forged aluminum pistons are made from 2xxx grade aluminum alloys (as I understand). Modern cast pistons are aluminum with graphite coated skirts to prevent scuffing. Diesel engines commonly have 2 piece pistons consisting of iron tops and aluminum skirts coupled together by the wrist pin
I’m curious if these fellas have failures due to material failure, or insufficient design/machining…? Machining pistons properly is not as straight forward as one might assume, and each material change requires new design parameters
Re: Piston material
Post by Norman Kling » Fri Nov 10, 2023 1:19 am
Most problems with aluminum pistons is caused be fitting to tight. Aluminum expands with heat at a greater rate than iron, so they need to be looser when cold. They will expand as the engine warms up, however, they can also seize if the engine overheats. In that case, you will stop faster than brakes can stop your car. and it could score the cylinder. Having said that, I use Aluminum pistons in all my cars, and as long as properly fitted and cooling system works well, have no problem. See other posts on fitting aluminum pistons.
Loftfield
First Name: Thomas
Last Name: Loftfield
Re: Piston material
Post by Loftfield » Fri Nov 10, 2023 7:29 am
Model T came with aluminum pistons. Whoever put them in failed to hone the wrist pins, a requirement for aluminium pistons. As note above, froze up, car stopped pretty quickly. Engine needed a serious overhaul, had it done professionally as absolutely everything needed to be replaced on engine and transmission. The fellow doing the work sent me pix of the aluminium piston melted. One serious lesson learned!
Re: Piston material
Post by TXGOAT2 » Fri Nov 10, 2023 9:16 am
Oil consumption used to be normal, even in fine cars. Aluminum pistons had some problems early-on, but better engineering design, experience, and better piston rings greatly reduced problems, including oil consumption, noise, collapsed skirt issues, cracking, and seizing. Better cooling systems contributed to lowering oil consumption and allowing more precise fits. Mechanics had to re-learn fitting procedure.
BobD
First Name: Bob
Last Name: Doris
Re: Piston material
Post by BobD » Fri Nov 10, 2023 10:38 am
X2. If one watches old movies, you will notice most prewar cars leave a puff of smoke when taking off. :)
tdump
First Name: Mack
Last Name: Cole
Re: Piston material
Post by tdump » Fri Nov 10, 2023 8:48 pm
Like a dummy I traded it in when I got my truck but my 96 cadilac had the Northstar v8 in it, ran like a striped ape, but from I was told, they had to loosen the tolerances at GM when the engine first came out and it was normal for it to use some oil. mine used a quart between changes.
