ruckstell adjustment
Topic author - Posts: 28
- First Name: mike
- Last Name: mclean
hi all I am working on a 22 centerdoor with a Ruckstell rear end I had a leak were the shift lever housing bolts on it has two 7/16 fine thread bolts on one side of the housing and one on other side is a 7/16 bolt and a 9/16's head with a lock nut below it and a point on it it to go into something inside any body know what the adjustment should be for this bolt thanks mike
Re: ruckstell adjustment
That bolt tightens down into the notch plate - one of two - snug it up good then tighten the jam nut.
- First Name: craig
- Last Name: leach
Hi Mike,
I found that the gasket did not mate the flange completely. I had to remove the shifter & make a gasket that fit better.
