Camshaft flange detail
Rajo T Speedster
Last Name: Rowe
* REQUIRED* Type and Year of Model Ts owned: 1918 RHD Speedster
Post by Rajo T Speedster » Mon Nov 13, 2023 8:46 am
Does anyone know if the flange near the front of a T cam is part of the cam machining or is it shrunk on?
Still trying to find a suitable cam for a Rajo OHV head engine.
John
Rajo T Speedster
Western Australia
OlGeezer
First Name: Andrew
Last Name: Turner
* REQUIRED* Type and Year of Model Ts owned: 1922 Runabout
Re: Camshaft flange detail
Post by OlGeezer » Mon Nov 13, 2023 10:28 am
I'm no expert, but from my experience, the flange near the front of a T cam is usually machined as part of the camshaft. I haven't heard of it being shrunk on separately.
Post by Jerry VanOoteghem » Mon Nov 13, 2023 11:49 am
I am certain that the flange is integral to the shaft and not an add-on piece.
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Nov 13, 2023 12:49 pm
Hi John,
If my memory serves me correctly the Rajo rocker arms are a1:2 ratio this will give you almost a 1/2" lift with a stock cam. If valve timing
is what you are looking to change I think Dan McEachern makes a timing gear set for that reason.
Post by RajoRacer » Mon Nov 13, 2023 1:06 pm
I installed a Chaffin's "modified" reground camshaft in my BB RAJO near 30 years ago now - it performs quite well !
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Mon Nov 13, 2023 1:47 pm
Many commercial Rajo heads used 1:1 rocker arms, so be aware.
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Mon Nov 13, 2023 1:55 pm
John, If you are going to run a reground Model T cam you will need to use a late 1924-27 T cam , the cam with the long front lobe. The earlier T cams use a shorter front lobe and a longer front bearing to take up thrust , but require modified front thrust when regrinding because the long front bearing won’t limit thrust on reground cam due to the cut down cam heal .
First Name: craig
Last Name: leach
Post by Craig Leach » Tue Nov 14, 2023 1:52 am
Hi Dan,
That is what I love about the Forum I get to learn something new every day.
John,
Kevin is correct about the early year regrind cams but if you have a Bosch timing cover distributer there is a thrust
adjusting screw in the cover for that. & the thrust washer kit is not expensive or hard to install most of the time.
