Looking for the proper air pressure for the above tire?
These are old Seiberling tires.
Due for replacement.
Many thanks!
Air pressure for a 32 x 4.5 TT tire?
Topic author - Posts: 278
- First Name: Brooks
- Last Name: Schlieben
- * REQUIRED* Type and Year of Model Ts owned: 1923 TT
- First Name: jeff
- Last Name: cordes
- * REQUIRED* Type and Year of Model Ts owned: 25
Re: Air pressure for a 32 x 4.5 TT tire?
I air my Chippewa tires to 60, they are 32x4.5 WW2 era tires.
- Last Name: Wrenn
Those were darned good tires back in their hey-day. They were literally the most round, well balanced tire on the market, they seldom needed the balance weights so commonly used. If I recall correctly they had a distinct look to them also...with what I'd call a small "lip" extending outward from where the sidewall met the tread. Dad had a set on his '65 Buick Wildcat and they sure rolled smooth. This was just before he then went to radials when they hit the market.TheSaintDiscJockey wrote: ↑Mon Nov 13, 2023 9:34 amLooking for the proper air pressure for the above tire?
Many thanks!
I run 45 - 50 lbs. - TT's ride so rough anyway !
