magnaflux
Philip
First Name: Philip
Last Name: Thompson
* REQUIRED* Type and Year of Model Ts owned: 1924 touring
magnaflux
Post by Philip » Thu May 23, 2019 2:29 pm
has anyone had a block magna fluxed. lately if so what did it cost. philip
Les Schubert
First Name: Les
Last Name: Schubert
Re: magnaflux
Post by Les Schubert » Thu May 23, 2019 2:48 pm
I’ve never bothered, as the cracks are generally visible to the naked eye. Bottom of the water jacket, especially behind the water inlet. Also look inside the valve chamber. And then look between the valve seats and the cylinder bores. After hot tanking the cracks are usually quite obvious.
Crankshafts I Always get magnafluxed I usually measure first, and if they won’t clean up at bigger than.020” undersize I set them aside!!
J and M Machine
Last Name: Gulbankian
Re: magnaflux
Post by J and M Machine » Thu May 23, 2019 3:03 pm
We typically charge $80.00 . In order for the magnaflux to work properly the block has to be perfectly clean,no paint,oil or dirt.
Philip
First Name: Philip
Last Name: Thompson
Re: magnaflux
Post by Philip » Thu May 23, 2019 4:13 pm
thanks guys a chapter member has a block he is willing to give me for my car he just wants the cost of the magnaflux back 100.00
seems like a nice round number. philip
Re: magnaflux
Post by Allan » Thu May 23, 2019 8:45 pm
Philip, the charge often includes two processes. To do the job well requires the block to be thoroughly cleaned first. This may mean hot tanking the block prior to the crack test.
Steve Hughes
Last Name: Hughes
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring 1921 Centerdoor
Re: magnaflux
Post by Steve Hughes » Thu May 23, 2019 11:29 pm
I just had a block done. Wasn’t hot tanked. It is baked at a high temperature then blasted with a fine steel shot. Then magnafluxed. It cost me $100.
