Best solvent for dissolving epoxy putty
jiminbartow
Topic author - Posts: 2452
- Last Name: Patrick
I have a cast metal piece that was repaired sometime in the past using a grey epoxy putty. Either Devcon or JB Weld. The person who did the repair did not line the two edges up properly and so the two edges have a gap and are the two surfaces are not flush. In order to repair it properly, I need to immerse the item in a bath of solvent long enough to dissolve the epoxy putty and allow the two pieces to separate. Does anyone know of the best solvent to use for this. Thank you. Jim Patrick
Ruxstel24
- Last Name: Hanlon
Re: Best solvent for dissolving epoxy putty
Not sure what is going to touch that stuff.
I would think some heat would get it to release, and just scrape it off.
Erik Johnson
- First Name: Erik
- Last Name: Johnson
Ed Fuller
- First Name: Ed
- Last Name: Fuller
- Board Member Since: 2012
I have removed epoxy or JB weld from a part by media or sand blasting it away.
RustyFords
- First Name: Don
- Last Name: Allen
It comes off pretty fast using a wire wheel....either a stationary one or one on a little Dremel tool.
1924 Touring
Russ_Furstnow
- First Name: Russ
- Last Name: Furstnow
- * REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo,1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet, 1917 Coupelet
If you soak the part in lacquer thinner, it will soften the J-B Weld and it will come off easily.
I hope this helps, Russ Furstnow
Kaiser
- First Name: Leo
- Last Name: van Stirum
only thing that will dissolve epoxy is acetone, be sure to ventilate !
Leo van Stirum, Netherlands
George Andreasen
- Last Name: Andreasen
- * REQUIRED* Type and Year of Model Ts owned: 0...building from parts
I'm not sure that acetone will dissolve JBWeld, but then again, I've never tried it. One thing I DO know is that epoxies of any type lose their strength rapidly when heated. JBWeld, when heated to approximately 500 degrees Fahrenheit (propane torch), will simply crumble away. Any residue is easily scraped off afterwards.
Of course, the main question is whether the base metal will take the heat without damage. I'd have no fear heating steel, brass or even aluminum to that temperature, but if your cast piece is "pot metal.......find another way.
jiminbartow
Thanks everyone. It took a long time of soaking, but acetone did the trick and softened the epoxy putty enough to scrape away in layers, allowing the acetone to work on the layer below. Jim Patrick
Nv Bob
- First Name: Bob
- Last Name: Middleton
- * REQUIRED* Type and Year of Model Ts owned: 18 roadster 1810 brand X
Wow may is almost over looking back on this month been busy
Mounted 15 clintcher tires
Rebiult standard rear axel
Put in new gas tank
1 band job
Rebiult holley NH
Rebiult coil box
Put on new lined brakes
Sold a T
Drove the new T
Hopefuly finish up a valve job drive new T more
Put in new gas tank
1 band job
Rebiult holley NH
Rebiult coil box
Sold a T
Drove the new T
