Speedometer installation problem
Allen Banks
Topic author - Posts: 37
- First Name: Allen
- Last Name: Banks
- * REQUIRED* Type and Year of Model Ts owned: 1923 Roadster
The mounting bracket isn’t squared up to spindle arm. I don’t think the clamp on the mount is movable. I believe it’s welded in place. I haven’t tried moving it for fear of breaking it. Anyone?
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Re: Speedometer installation problem
The clamp is a separate piece and should be lose on the spindle nut extension, and should be able to rotate. Remove the bolt in the end and tap the clamp until it breaks loose.
Allen Banks
- First Name: Allen
- Last Name: Banks
That was the issue, just painted on there pretty good. A nice tap in the clamp freed it up.
- First Name: Henry
- Last Name: Lee
Looks like powder coated glued/melted on. You may need to heat it up to loosen it.
