What number key do i have?
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Tue Nov 21, 2023 1:53 pm
I am just wondering what number key i have in case i want to get an extra or another key.
First Name: Austin
Last Name: Farmer
Re: What number key do i have?
Post by 1925 Touring » Tue Nov 21, 2023 1:56 pm
Last Name: Strange
Post by CudaMan » Tue Nov 21, 2023 1:58 pm
Look closely at the front of the lock that the key fits, it should have a number stamped into it that matches the number of your key.
https://www.mtfca.com/discus/messages/4 ... 1405770514
Been Here Before
First Name: George John
Last Name: Drobnock
Post by Been Here Before » Tue Nov 21, 2023 2:16 pm
Sorry for the quality of the photograph, but with an increase magnification a number can be seen to the left of the key slot.
Langs list some ford keys with numbers - https://www.modeltford.com/model-t-part ... ches/keys/
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Tue Nov 21, 2023 2:21 pm
The Key Austin has is for a modern repro switch, the design of which fits a #55, but they do not interchange, as the groove centering does not match.
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Tue Nov 21, 2023 2:32 pm
Will do, thank you!
Post by TRDxB2 » Tue Nov 21, 2023 2:47 pm
No number + brass key = repro #55 https://www.macsautoparts.com/catalogse ... nition+key
#55 key.png (203.04 KiB) Viewed 2556 times
Jim Goldens comment is also correct in how they fit original tumblers. They fit the repro tumblers. Easy identification to is the shape of the top & no number. These may fit CLUM brand, rectangular plate, switches that were made for a Model T though. Haven't tried, no parts
Ed Fuller
First Name: Ed
Last Name: Fuller
Board Member Since: 2012
Post by Ed Fuller » Tue Nov 21, 2023 5:26 pm
Jim is correct. That key is for the modern reproduction tumbler.
Lang’s and Snyder’s both have duplicates for that key.
Make sure when you order to tell them you want a duplicate key for the reproduction switch. The duplicates they have don’t have a number stamped on them.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Wed Nov 22, 2023 10:58 am
Then too, the number Austin is looking for on the key cylinder is not there either.
Don Demio
First Name: Don
Last Name: Demio
Post by Don Demio » Sun Nov 26, 2023 8:38 am
If you look closely at the photo Frank posted above of the three keys you will see the key shaft bittings are the same, however the keyway (groove) locations are different. Model T Ford keys only have a keyway on one side and NOT all are centered on the shaft. While some are centered, some are offset to the right and some to the left. These differences are designed to help create the 24 variations in the Model T Ford ignition keys 51 - 74. The Model T Ford Master Key sets are composed of only 4 keys. They are so thin no keyway interaction is required to operate the switch.
Don Demio
First Name: Don
Last Name: Demio
Post by Don Demio » Sun Nov 26, 2023 8:49 am
Here are a thousand words!!
Key Numbers Patterns and Keyway Locations Photo.docx
(957.35 KiB) Downloaded 132 times
Moxie26
Last Name: Jablonski
Post by Moxie26 » Sun Nov 26, 2023 9:10 am
Don....
File refuses to download, says it's corrupt.
Phoenix88R
First Name: Doug
Last Name: Wilson
Post by Phoenix88R » Sun Nov 26, 2023 10:31 am
The file opened for me as a word document.
Last Name: Strange
Post by CudaMan » Sun Nov 26, 2023 11:12 am
The file went to my "downloads" directory and I was able to open it as a Word document from there. :)
Moxie26
Post by Moxie26 » Sun Nov 26, 2023 11:18 am
Thanks for the tips, file opened just fine
Post by TRDxB2 » Sun Nov 26, 2023 11:51 am
Here is the image in the file above with some explanation.
The lock cylinder has 4 slots for the wafers that ride up or down. When the key is inserted they're all aligned top & bottom so the key can be turned .
Just one wafer size is needed to create 6 usable combinations by orientating the wafers in different permutations in the 4 slots
Other combination are achieved by just flipping the key pattern over and grooving the keyway on that side.
Look closely (51, 52, 53) and you can see that the keyways for the same cut key are shifted: center, to the left & to the right. Then flipped over for 54, 55, 56 with similar keyways. Since the Master keys have no keyways they kit 51-53 & when flipped over 54-56 etc
4 wafer patterns x 2 wafer orientations x 3 keyway positions = 24 possible combinations & permutations
Don Demio
First Name: Don
Last Name: Demio
Post by Don Demio » Sun Nov 26, 2023 1:56 pm
Frank,
Thanks for posting the photo. I am analog in this digital world. Your added text and photos really cleared up any confusion on the subject.
U da man,
Don
