Rocky Mountain brakes for Pasco wire wheels
AndyO
First Name: Andy
Last Name: Oldman
* REQUIRED* Type and Year of Model Ts owned: 1912,1915,1926
Post by AndyO » Wed Nov 22, 2023 5:37 pm
Hi Folks
Has anybody a method to install Rocky Mountain brakes or something similar for my speedster which has small drums and Pasco wire wheels. ?
The small drums were relined but are not good for much except as an E brake. Thanks Andy .
First Name: craig
Last Name: leach
Re: Rocky Mountain brakes for Pasco wire wheels
Post by Craig Leach » Thu Nov 23, 2023 1:15 am
Hi Andy,
Most brake verses wheel issues can be solved by spacing the wheels out to get the needed clearance. Best I recall Pasco wheels bolt to the wire
wheel bolt pattern so spacers may be had on line. & you will need bolts to accommodate the spacing. Keep in mind that spacing the wheels out
will add stress to the wheel bearings & axles so be diligent with those parts.
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Thu Nov 23, 2023 11:30 am
Your Pasco wheels will work just fine with accessory brakes. Bear end mind that the hub bolts are specifically for the Pasco wheel as the both secure the hub/drum but are also the drive pins. If stacking the second drum for the Rockies your bolts will probably be too short. In a speedster or roadster I’d probably stick to a small drum AC brake. If you need to replace your hub bolts you’ll probably have to have some made. I recommend contacting Kevin Pharis about that.
Andy
AndyO
First Name: Andy
Last Name: Oldman
Post by AndyO » Thu Nov 23, 2023 1:43 pm
Hi thanks Are AC brakes still available ?
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Thu Nov 23, 2023 7:47 pm
There’s a current AC brakes thread with the new makers contact info.
Andy
