Another use for reverse gear bushes.
Post by Allan » Thu Nov 23, 2023 12:17 am
Previously I have used sections of a reverse gear bush to rebuild brass truss rod mountings where the spring leaf hanging from worn shackles wears a groove in the mounting bracket.
Today I used another piece of the same bush to repair a broken bottom radiator outlet
The piece was shaped and silver soldered in place.
I used to put them in the scrap bin but glad this one hadn't made it.
First Name: craig
Last Name: leach
Re: Another use for reverse gear bushes.
Post by Craig Leach » Thu Nov 23, 2023 12:48 am
Thumbs up on that.
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Fri Nov 24, 2023 9:35 pm
Never throw out an old bushing.
Andy
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Sat Nov 25, 2023 2:29 pm
Another use for a reverse bushing. :D
Respectfully Submitted,
Be_Zero_Be
Post by Allan » Sat Nov 25, 2023 3:51 pm
That's really neat Bob. Are there laws governing the height or rear lamps in Washington? Here I could mount those to the top support arms to act as eye level brake lights. I love the red tourer. My 15 tourer was also red, a little more maroon than yours.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Sat Nov 25, 2023 6:07 pm
I am not aware of any laws concerning tail light height.
The reason that I extended the light below the top cradle
was to make the light visible when the top is folded down.
Be_Zero_Be
Post by Allan » Sun Nov 26, 2023 4:25 am
That makes sense.
