SOLDModel T "SUPER-FORD" Racing Chassis Front Axle SOLD!
1902Crest
First Name: mike
Last Name: west
* REQUIRED* Type and Year of Model Ts owned: one
Post by 1902Crest » Mon Nov 27, 2023 8:53 am
SOLD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!I have this axle that Ive been told is for a Ford performance chassis. The spring perch pads are adjustable by loosening a through bolt and slid them in or out for different width frames. Also the Camber is adjustable as the lower bushing seems to have a off center hole . There is a segmented adjustment washer that allows the king pins to be set for the camber desired. It came out of a old building with much more Ford T parts , so maybe this is infact what it is. Also it is setup for right hand drive but may be able to switch that. Mike West Livonia NY 585 738 1541 if anyone has any ideas or interest in the axle. More pictures available . SOLD!!!!!!!!!!!!!!!!!!GONE!!!!!!!!!!!!!!!!!!!!!!!!!!!
