Needed pieces.
Needed pieces.
Post by Dollisdad » Tue Dec 05, 2023 3:54 pm
One set of good front wheel bearings, races, washers and nuts.
One not so good same setup. For display, not road use.
One thrust washer and one steel washer for rear end for display.
Re: Needed pieces.
Post by TRDxB2 » Tue Dec 05, 2023 5:02 pm
Have most of that! Not sure about the inner bearings
For the outer sets : the Timken races are brand new. Have several used Timken VG sets of bearings. Also one not so good is a bit loose but very shiny not Timken. The thrust washer is brand new, used steel washer. Will send pictures in a PM later.
Re: Needed pieces.
Post by Original Smith » Tue Dec 05, 2023 5:36 pm
It would be nice if Tom would indicate what year bearings he's looking for!
Re: Needed pieces.
Post by TRDxB2 » Tue Dec 05, 2023 6:38 pm
Good question. Assumed for this speedster, looks like wire wheels in the back but could be for another .....
Re: Needed pieces.
Post by TRDxB2 » Tue Dec 05, 2023 9:23 pm
Sent you a PM RSVP email would be easier
Joe Bell
First Name: Joe
Last Name: Bell
Re: Needed pieces.
Post by Joe Bell » Tue Dec 05, 2023 9:48 pm
Tom, I have coffee cans of bearings and original thrust washer and some brass ones. Remind me the next time we see each other.
