pinion 11 tooth
Melba Nolan
First Name: Melba
Last Name: Nolan
* REQUIRED* Type and Year of Model Ts owned: 23 roadster
pinion 11 tooth
Post by Melba Nolan » Fri Dec 22, 2023 7:33 pm
For sale: 11 tooth pinion $75 plus postage
Melba Nolan
First Name: Melba
Last Name: Nolan
Re: pinion 11 tooth
Post by Melba Nolan » Sun Jan 21, 2024 11:34 pm
move to top
Re: pinion 11 tooth
Post by Allan » Sun Jan 21, 2024 11:40 pm
The critical part of a used pinion is the amount of wear on the teeth. If you show the other side of the gear, you may have better luck selling it. The price is right, if the wear is right.
Melba Nolan
First Name: Melba
Last Name: Nolan
Re: pinion 11 tooth
Post by Melba Nolan » Mon Jan 22, 2024 12:32 am
thanks I will do that
Melba Nolan
First Name: Melba
Last Name: Nolan
Re: pinion 11 tooth
Post by Melba Nolan » Fri Jan 26, 2024 6:08 pm
those are 2 different pinions. I have a picture of the other side of the bottom one but can't post. can email or text
melbanolan@aol.com or 314+575-7115 price same for either plus postage
RVA23T
Last Name: C
Re: pinion 11 tooth
Post by RVA23T » Sat Jan 27, 2024 6:51 pm
Posting Additional Pictures of Teeth for Mr. Noland.
RVA23T
Last Name: C
Re: pinion 11 tooth
Post by RVA23T » Sat Jan 27, 2024 6:52 pm
Additional Pictures of the G2 marked with Ford script
