1926-27 Gooseneck Spare Tire Carrier
Don Demio
First Name: Don
Last Name: Demio
Post by Don Demio » Thu Jan 04, 2024 11:31 am
WTB Model T Ford 1926 -27 Wire Wheel Gooseneck Carrier. Must have good end to attach under rear spring. Damaged tire mounting plate or bolt threads are not important. Carrier to be modified as a trailer hitch. Respond via email to ggunrunratattdot net. Thanks for your attention
Ken Buhler
First Name: Ken
Last Name: Buhler
Board Member Since: 2012
Re: 1926-27 Gooseneck Spare Tire Carrier
Post by Ken Buhler » Thu Jan 04, 2024 7:49 pm
Don, I have a part that will be perfect for your needs. It is the bracket part that bolts on and can be attached to for your hitch. Cheaper to ship also. I'll send photos to your email but you need to send me clarification of yours.
Work honestly
Stay true to your word
Get the job done right
Don Demio
First Name: Don
Last Name: Demio
Post by Don Demio » Thu Jan 04, 2024 9:52 pm
Ken,
My email is all spelled out so I don't get spam or a virus. You will need to use the symbols and there should not be a space between the t and n. Thanks
Don
Ken Buhler
First Name: Ken
Last Name: Buhler
Post by Ken Buhler » Fri Jan 05, 2024 11:42 am
Hello Don,
I tried variables of the email you posted but the system does not recognize any of them.
I saved this piece for the possibility of someone wanting to make a hitch.
It is a strong base to build from. I think, considering the time to box and send it, $35.00 plus postage would be fair. I will find the least cost of shipping if you want me to pursue this. My postal code is V1W 2X6 in Kelowna B.C. Canada.
Best regards,
Ken Buhler
Work honestly
Post by TRDxB2 » Fri Jan 05, 2024 2:08 pm
The best way for members to contact you is for the to use the FORUM's options of sending a PM or email. This is done by them clicking on your userid
Don Demio. Only register users can do this. Trying to encrypt your email address doesn't always prevent scammers from decrypting it In any case you left out the Internet Provider potion xxxx that goes after the @ like @xxxx.net
