FS: Brass Top Non Model T Coil
Last Name: House
Post by George House » Mon Jan 08, 2024 5:30 pm
I believe probably for a one cylinder engine. Excellent wood, black brass top and nearly new KW points.
Only $50 + mail cost. Personal check is fine.
gwhouse731(at)gmail(dot)com
YellowTRacer
First Name: Ed
Last Name: Archer
Board Member Since: 2009
Re: FS: Brass Top Non Model T Coil
Post by YellowTRacer » Mon Jan 08, 2024 6:16 pm
Hey George, I need a coil for an early Brush automobile. This looks a little similar but I need measurements to see if it will fit in the box. Also more pictures. The coil I need has 3 contact points. One on the front and one on each side near the top like the one in your picture.
Ed aka #4
Last Name: House
Post by George House » Tue Jan 09, 2024 9:35 am
Howdy Ed,
…..Good question, so I’ve included these 3 pictures. If the measurements will fit your coil box, I’d be inclined to ask Brent Mize if he could ‘remodel’ the coil to work..gh
Last Name: House
Post by George House » Fri Jan 12, 2024 4:23 pm
My only ***btt*** this ad before it sinks into oblivion 😔
YellowTRacer
First Name: Ed
Last Name: Archer
Post by YellowTRacer » Fri Jan 12, 2024 7:14 pm
THanks George, never hurts to try, It's too thin and too tall and not close enough to even think, maybe, with some alterations.
Ed aka #4
Brent Mize
First Name: Brent
Last Name: Mize
* REQUIRED* Type and Year of Model Ts owned: 1927 Sport Touring & 1927 Sport Runabout
Post by Brent Mize » Sat Jan 13, 2024 7:33 am
George,
The coil you have is the vibrator for a master vibrator.
It has no secondary winding. It does not produce a spark.
It’s simply used to fire the coil that have their points shunted out.
It was used to smooth out the operation of 4 coils all firing differently.
Brent
The Coil Doctor
Last Name: House
Re: FS: Brass Top Vibrator For a Master Vibrator
Post by George House » Sat Jan 13, 2024 4:36 pm
Oh…..OK….. Thanks Brent 🙏 Then, does it have true value ?
Ron Patterson
Post by Ron Patterson » Sat Jan 13, 2024 6:42 pm
George
The pictured coil came oit of a KW Master vibrator.
It is unique in taht it has no secondary winding.
Ron Patterson
