FS: Model T Ford Right Sidelight & Taillight
Junkyard4
First Name: Paul
Last Name: Jacobs
* REQUIRED* Type and Year of Model Ts owned: 1914 American Touring 1914 Canadian Touring
Board Member Since: 2010
Post by Junkyard4 » Fri Jan 12, 2024 1:24 pm
Model T Ford Right Sidelight & Taillight. The sidelight is in nice condition and complete. The taillight has a good size dent in the side and the burner is missing but could be easily restored. The glass is all in good condition. Located in Libertyville Illinois but I am willing to ship. $50 for the pair.
Private message, call or text 847-508-3634
Re: FS: Model T Ford Right Sidelight & Taillight
Post by Wayne Sheldon » Sat Jan 13, 2024 5:59 am
They both look to be tail lamps. One appears to be a Ford-O late oil taillamp, while the other is a typical 1918 to mid 1920s taillamp. Hard to tell from the photos. Can't make out the colors of the glass. Glass in either case may have been replaced at some time however.
These type sidelamps from the Ford factory never had a smaller side lens facing out, However, the companies that manufactured the oil lamps for Ford also made after-market and replacement lamps to be sold by others. Those did include similar style sidelamps which did have the second lens facing out to one side. Those could be purchased and used as replacement sidelamps. Or were also sold for commercial use on trucks to be mounted on the back of the cab so workers could see in the night to load trucks for early deliveries. You don't see them used that way very often. However, I have seen a few era photos showing those lamps used that way.
And, I have a pair of those lamps myself. That is why I noticed them in a few pictures.
