'14 Touring, Brass Screw Questions
Ben Umberger
First Name: Ben
Last Name: Umberger
* REQUIRED* Type and Year of Model Ts owned: 14 Touring, 20 Touring, 27 Touring
Post by Ben Umberger » Mon May 27, 2019 7:03 pm
Gents,
I know I should have taken detailed pictures, I should have bagged and meticulously labeled the parts. Don't beat me up too bad please. I have a 14 Touring and am not sure some of the parts go. Hopefully someone can help.
The arm rests are held on with Brass screws with a cup shaped washer
Question 1, What is the proper name for these type washers?
In the picture you will see that some of those washers are shaped differently from the others, I don't know why or where to put each kind. In the picture the Left column is more "cupped" while the the right side is more shall we say "Angled".
Question 2, How would you describe the difference (teach me some vocabulary)
Question 3, Where does each kind go?
4 of the screws are painted black,
Question 4, Is this someones way of making do with what they have on hand or do the painted ones belong somewhere specific?
Ben
Re: '14 Touring, Brass Screw Questions
Post by Allan » Mon May 27, 2019 7:12 pm
Ben,
1. We call them cup washers. They vary depending on the manufacturer, not application.
2. They are usually fixed with raised head countersunk nickel plated screws. You blokes call them oval head?
3. I am not sure they belong anywhere on a standard T, but US cars my have them.
Hope this help.
HornsRus
First Name: Charley
Last Name: Shaver
* REQUIRED* Type and Year of Model Ts owned: 1913
Post by HornsRus » Mon May 27, 2019 8:04 pm
early door check straps use that set up.maybe other spots.charley
TonyB
First Name: Tony
Last Name: Bowker
Post by TonyB » Mon May 27, 2019 8:38 pm
My 1924 coupe uses nickel plates cup washers to hold the door panels to the wood frame. I’m not sure that’s how Ford built them....
Tony Bowker
La Mesa, California
Post by Original Smith » Mon May 27, 2019 9:46 pm
You should be able to use those up on the check straps.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Tue May 28, 2019 12:20 am
Finish washer, used with an oval head (or French) screw.
Greg Griffin
First Name: Greg
Last Name: Griffin
* REQUIRED* Type and Year of Model Ts owned: '14 torpedo, '25ish pickup
Post by Greg Griffin » Wed May 29, 2019 10:43 pm
A French screw is a brass oval head screw with a polished head. Different size finish washers for different size screws. Ford used some oddball sizes like #5; you can find them on the internet.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Wed May 29, 2019 11:09 pm
I don't know where on an armrest these would have been used.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Wed May 29, 2019 11:10 pm
I don't know where on an armrest these woul have been used.
Post by Allan » Thu May 30, 2019 5:52 am
Their use on check straps is understandable, as they spread the clamping force over a wider area, especially useful on fabric straps. What is not understandable, given Henry's penchant to save a cent or two wherever possible, is why a two piece, plated, brass assembly might be used in place of a steel round head screw.
George Mills
Last Name: Mills
Post by George Mills » Thu May 30, 2019 10:15 am
Ben,
Body parts are almost impossible to sort...almost need a real Rip-Van-Twinkle to go side by side.
They are called 'cup' or 'finishing' washers as others have mentioned...
There are no standards as to size and shape that I know of...
They are usually used where an oval head screw is required, but in an over clamping (non-countersunk) trim piece...
As others point out, they spread out the force, provide some cinch where the outer ring clamps, and provide that pocket for the base of an oval screw to hide...
Going thru the parts books, I found this....may or may not help you sort...(I have no idea what a back-stay is)
Last Name: House
Post by George House » Thu May 30, 2019 10:39 am
Finally....Keith said it - twice. I, too, don’t know where a wood screw and cup washer combination would be used on a ‘14 touring armrest. To the best of my limited ability; I restored a ‘14 runabout and never researched an original screw/cup washer unit installation. Saw many a beautiful ‘14 touring and none had this. But if it’s a matter of individual preference, I say ‘Go for it’...
