flat head slot screw size
NY John T
Topic author - Posts: 443
- Last Name: Killelea
Hi all,
I'm working on the interior of my 27 Tudor and I need the size of the flat head slotted screw that holds the window decorative moldings to the body. They look to be about 1/4 inch screws and are about 1/2 inch long. My threads are all chewed up and/or missing. Does anybody know the size of these small screws? They are a fine pitch, but I need the size. Thanks.
John
John
Rich P. Bingham
- First Name: Rich
- Last Name: Bingham
Re: flat head slot screw size
Not sure of the size, but I'm pretty sure they were oval head slotted, not flat. Others will know better. I sorely miss slotted head screws.
Get a horse !
- Last Name: Wrenn
If my '26 Fordor is any indication and similar, yes they're slightly oval headed and mine are the nicest looking chrome screws you ever saw!Rich P. Bingham wrote: ↑Sun Jan 21, 2024 11:11 amNot sure of the size, but I'm pretty sure they were oval head slotted, not flat. Others will know better. I sorely miss slotted head screws.
NY John T
Sorry, they're definitely not the nice chrome oval headed screws that show. These hold the metal piece around the rear side windows to the body. The same screws are used to hold the large sheet metal piece (which holds the window crank in place) on to the sides.
- Last Name: Wrenn
So then these are like under the otherwise nice trim with the nice chrome screws that I see in mine? Later if I get my lazy butt out to the cold barn I'll look and maybe even send a pic?NY John T wrote: ↑Sun Jan 21, 2024 1:32 pmSorry, they're definitely not the nice chrome oval headed screws that show. These hold the metal piece around the rear side windows to the body. The same screws are used to hold the large sheet metal piece (which holds the window crank in place) on to the sides.
If they are not seen, you could use more readily available Phillips head screws. Her in Oz, if they have a flat top, we describe such screws as countersunk, and your oval heads as raised countersunk.
J1MGOLDEN
- Last Name: Golden
14 X 24 Treads Per Inch were used in several places and are only about .003 smaller than 1/4th inch, so they might be used there.
jab35
- Last Name: Bartsch
John. Here's a link that shows examples of the trim screws in a 52 piece kit for the 27 Tudor. https://www.macsautoparts.com/model-t-f ... 040-1.html
Disclaimer: This link is for illustration only I'm NOT soliciting business for this company.
I am 99% certain there are no 14-24 bolts/machine screws used in this interior trim application.
I am 100% certain Don Booth can answer your question, he's restored a number of the improved fords, but rarely posts here currently. An excellent and trusted source of information (and trim screws) is Langs. https://www.modeltford.com/item/673.aspx Call them for info and to order. Best of luck, jb
