Vaporizer Linkage
Last Name: Hatch
Vaporizer Linkage
Post by Dan Hatch » Sat Jan 27, 2024 3:18 pm
Can someone post a picture or two of a 27 Touring with Vaporizer link. You know choke linkage, etc. Thanks Dan
Last Name: House
Re: Vaporizer Linkage
Post by George House » Sat Jan 27, 2024 4:02 pm
Do you specifically need a ‘27 touring ? If so, I ain’t got no ‘27 touring but I hope this helps. The choke wire fastens to a spring loaded lever inboard of the intake throat. See the outboard choke lever on the same shaft with nothing fastened for hand crank choking.
Jim Eubanks
First Name: Jim
Last Name: Eubanks
* REQUIRED* Type and Year of Model Ts owned: 1926 touring, 1927 cpe
Post by Jim Eubanks » Sat Jan 27, 2024 5:31 pm
I have a 26 and a 27 both with vap manifolds and linkage is same on both.
Last Name: Hatch
Post by Dan Hatch » Sat Jan 27, 2024 5:45 pm
Thanks for the picture, but how about one taken farther back. Need to see more of the mixture rod. Thanks Dan
Moxie26
Last Name: Jablonski
Post by Moxie26 » Sat Jan 27, 2024 6:54 pm
Picture from Bruce's book
Close up of two choke rods. Thank you Mr.McCalley
Moxie26
Post by Moxie26 » Sat Jan 27, 2024 6:56 pm
From Bruce's book
Last Name: House
Post by George House » Sat Jan 27, 2024 8:27 pm
Thanks Bob. I didn’t know how the choke wire thru the radiator looked. Now I see the bend several inches behind the radiator. I guess that’d be clotheshanger gauge wire ?
Moxie26
Post by Moxie26 » Sat Jan 27, 2024 8:44 pm
Hey George .... The regular brass choke wire that our vendors sell fits the use a little bit better than the larger gauge clothes hanger wire.... One length will would be slightly longer from outside the radiator to the choke lever at the vaporizer, conversely, not enough wire to fit between the inside vaporizer choke lever to the mixture rod anchor.. so another length of wire would be used to match and cut to length.
Last Name: Hatch
Post by Dan Hatch » Sun Jan 28, 2024 3:19 am
Thanks that is what I needed
FundyTides
First Name: David
Last Name: Wilson
* REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
Post by FundyTides » Sun Jan 28, 2024 9:42 am
Dan, here's a picture I have on hand of rthe vaporizer on my 27 (Canadian) Touring. If you still need more detail, let me know and I can get more pictures. I believe that the rod going from the choke lever to the mixture rod is original Ford part (6299), while the wire going out through the rad cover is just a piece of copper wire that I used to replace the missing one on the car.
Moxie26
Post by Moxie26 » Sun Jan 28, 2024 11:01 am
Close-up on choke linkage
Ed Baudoux
First Name: Edward
Last Name: Baudoux
Post by Ed Baudoux » Sun Jan 28, 2024 11:04 am
It's common for the choke return spring to be broken. It wraps around the butterfly shaft. I've seen a few on them with an additional spring mounted externally. Without it, the choke will suck itself shut.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
jiminbartow
Last Name: Patrick
Post by jiminbartow » Sun Jan 28, 2024 7:44 pm
