Loose wheel bearing race
Belliott3
First Name: Bill
Last Name: Elliott
* REQUIRED* Type and Year of Model Ts owned: 1916 Model T Touring
Board Member Since: 2006
Post by Belliott3 » Thu Feb 01, 2024 5:37 pm
Ok, so I finally got around to removing all four taper bearing races from my wheel hubs. I’ll be putting in all ball bearing races, but one outside race is a little loose. What is the best thing to use to keep it in place?
First Name: craig
Last Name: leach
Re: Loose wheel bearing race
Post by Craig Leach » Thu Feb 01, 2024 6:04 pm
Hi Bill, This seems to be coming up a lot lately. This is what I did the last time. I picked up a cheap single knurling tool with 6 different wheels.
Cut it off & welded it @ a 90* on the end. Indicated the hub in the lathe & knurled the I D then smeared green Loctite on the hub & pressed it
in. Loctite 660 can also be used as was pointed out the last time this came up. If the hub is still in the wheel knurling like this is really not a
option.
Last Name: Strange
Post by CudaMan » Thu Feb 01, 2024 6:08 pm
Some folks have tried dimpling the housing in multiple places with a punch to get a (temporarily) better fit. Each punch dimple produces a raised area around its circumference.
Also, Permatex makes a line of Loctite products specifically to address loose bearing fits:
https://www.permatex.com/product-catego ... compounds/
Post by speedytinc » Thu Feb 01, 2024 6:28 pm
The knurl job looks good. I would still use a little locktite product.
If the gap is on the large side, I have had excellent service with locktite 660.
Choose your locktite product it match the gap.
"Straw-berrying" the inside, from what I have seen, isnt a permanent fix alone.
There isnt enough raised metal to stay tight.
Belliott3
First Name: Bill
Last Name: Elliott
Post by Belliott3 » Thu Feb 01, 2024 7:03 pm
Locktite 669? Where do you find it?
Last Name: Strange
Post by CudaMan » Thu Feb 01, 2024 7:14 pm
havnfun
First Name: Joe
Last Name: Kowalczyk
Post by havnfun » Thu Feb 01, 2024 8:25 pm
I use the raspberry method and loctite 660, bolt together with a dry bearing, let sit overnight or longer, then take bearing out and grease good and assemble. I’ve had fantastic luck with this method, especially on front wire wheel hubs.
Regards,
Post by speedytinc » Fri Feb 02, 2024 8:04 am
Sorry, typo - 660
Belliott3
First Name: Bill
Last Name: Elliott
Post by Belliott3 » Fri Feb 02, 2024 11:07 am
Forgive my ignorance, but what’s the raspberry treatment? Sounds yummy!
Post by speedytinc » Fri Feb 02, 2024 11:12 am
Its taking a center punch & punching a whole lotta times in the race area displacing metal.
Looks like a strawberry surface.
Last Name: Strange
Post by CudaMan » Fri Feb 02, 2024 11:32 am
