Axle gear
JBog
First Name: Jason
Last Name: Bogstie
Axle gear
Post by JBog » Sat Feb 03, 2024 12:46 pm
Are there any vendors that sell new axle gears? I see new axles at the vendors, but not the gears that attach to them.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Axle gear
Post by Dan McEachern » Sat Feb 03, 2024 1:05 pm
No need- there are plenty of good original gears out there. A good majority of trashed or worn axles have good gears on them.
Last Name: Hatch
Re: Axle gear
Post by Dan Hatch » Sat Feb 03, 2024 1:33 pm
There even some NOS gears if you know where to look. 😀
jab35
Last Name: Bartsch
Re: Axle gear
Post by jab35 » Mon Feb 05, 2024 12:04 pm
Jason: Lang's has helped me with items like this. They have many parts that are not listed in the catalog. Best, jb
JBog
First Name: Jason
Last Name: Bogstie
Re: Axle gear
Post by JBog » Mon Feb 05, 2024 12:42 pm
Thank you!
Adam
First Name: Adam
Last Name: Doleshal
Re: Axle gear
Post by Adam » Mon Feb 05, 2024 1:32 pm
The new axle shafts are 1.063”. Originals are 1.062”. The original gears can have variations in their inside diameter. Some are worn oversize and some are undersize enough to be too tight of a press fit on a new axle shaft. To do a good job of fitting a good used gear to a new axle shaft, you really have to measure the gear inside diameters all over with a dial bore gauge & pick a gear that has a good .0015” to .0020” press fit. You also need to have a good quality press that is large enough to press a gear off and on.
