Strange hole in wire wheel hub
lcleeton
First Name: Lawrence
Last Name: Cleeton
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1926 Runabout
Post by lcleeton » Sat Feb 03, 2024 6:22 pm
On my recently acquired 26 Runabout, one of the five wire wheels has this hole in the hub. Any ideas why it is there? I've considered it could be used for some kind of lock like a bicycle cable lock, but there doesn't seem to be a way to use a cable lock on the spare tire mount.
got10carz
Last Name: Meixner
Re: Strange hole in wire wheel hub
Post by got10carz » Sat Feb 03, 2024 7:49 pm
My only guess is it's there to access a grease zerk tapped into the hub.
Post by John kuehn » Sat Feb 03, 2024 8:24 pm
A grease zerk in the hub isn’t a bad idea. Slowly turn the wheel to see if you can see one.
I wouldn’t worry about it either way unless you’re a purist.
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Sat Feb 03, 2024 8:36 pm
A lot happens over the course of 100 years with different owners and mechanics making their mods and inflicting abuse, some sort of port for greasing the hub is a good guess. Hard to tell from the picture, is that chipped paint or a hole next to the lug nuts?
Last Name: Hjortnaes
Post by DHort » Sat Feb 03, 2024 9:55 pm
That is for the cicadas to rest during the day.
lcleeton
Last Name: Cleeton
Post by lcleeton » Mon Feb 05, 2024 4:00 pm
Just chipped paint with some rust behind it. I'm going to restore the wheels.
nicklm
First Name: Nick
Last Name: Miller
* REQUIRED* Type and Year of Model Ts owned: 1926 touring
Post by nicklm » Mon Feb 05, 2024 5:16 pm
If you have a mounting for a spare in the middle of the back of the car, it could be for a wire for a stop light.
