Rustoleum farm implement paint for block/head/pan?
NealW
First Name: Neal
Last Name: Willford
Post by NealW » Mon Feb 05, 2024 6:28 pm
I'm getting ready to paint the block, head, pan, hogshead and various other engine parts on a T engine that I'm rebuilding. I was wondering if anyone has used Rustoleum's farm implement paint to paint these items, and if so, were you happy with the results?
The spec sheet for the paint says that it's good for temps up to 212 degrees F, and if the coolant system is doing its job, I believe that the head and block shouldn't get that hot. I won't be painting the exhaust with that paint though!
thanks,
Neal
Last Name: Hatch
Re: Rustoleum farm implement paint for block/head/pan?
Post by Dan Hatch » Mon Feb 05, 2024 7:02 pm
What is wrong with engine paint?
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Mon Feb 05, 2024 7:19 pm
I actually use farm paint for my tractor blocks, heads, and pan.
NealW
First Name: Neal
Last Name: Willford
Post by NealW » Mon Feb 05, 2024 7:43 pm
Nothing! I couldn't get it locally in quart cans and the next couple of days will be warm enough outside that I'd like to paint all the parts before our winter temps come back. I picked up a can of the farm implement paint today, and was just wanting to see if anyone has actually used it on their engine parts before I did so.
Afrazer
First Name: David
Last Name: Frazer
* REQUIRED* Type and Year of Model Ts owned: 1925 closed cab TT. 1925 factory roadster pickup. 1926 two door sedan
Post by Afrazer » Mon Feb 05, 2024 10:21 pm
Hey Neal. I’ve used some in different applications and I thought it did fine. I’m trying some paint from a locally place this time for the block and head but I’ll paint the pan using the farm implement paint. Are you planning on brushing or spraying?
1925 closed cab TT
1926 two door sedan
NealW
First Name: Neal
Last Name: Willford
Post by NealW » Mon Feb 05, 2024 10:30 pm
I'm planning on using my HPLV gun. I'm also going to check with wholesale automotive paint in Wichita tomorrow to see if they have some engine enamel paint.
Afrazer
First Name: David
Last Name: Frazer
Post by Afrazer » Mon Feb 05, 2024 10:46 pm
I got my block paint from Auto and industrial paint supply in newton on broadway and it was ready to spray mix in a quart can and sprayed on really nice. I don’t know how it will hold up as I haven’t used them before.
1925 closed cab TT
1926 two door sedan
signsup
Last Name: Brough
Post by signsup » Tue Feb 06, 2024 1:07 pm
The consensus on another vehicle forum I am active on is that the blocks should not get that hot to affect almost any paint. If it does, you got other problems. So, go for it. Here is my latest engine project painted Model A green.
I have had good luck using black stove polish on manifolds. Wipes on and will stay a nice matte black finish for over a hear. Then wipe on again. Available at ACE hardware here.
A bunch of old cars
Sometimes they run.
Sometimes, they don't.
Post by Steve Jelf » Tue Feb 06, 2024 2:16 pm
I have used regular Rustoleum rattle cans, with no troubles. Once I used glossy, but hated the look and switched back to satin.
Tmooreheadf
Last Name: Moorehead
Post by Tmooreheadf » Tue Feb 06, 2024 9:33 pm
Magic farm implement paint from Tractor supply works well!
NealW
First Name: Neal
Last Name: Willford
Post by NealW » Fri Feb 16, 2024 10:58 am
After reading that I'd probably want to add reducer and hardener to the farm paint to get it to spray well and dry in a reasonable amount of time, I decided to just get another quart of Eastwood extreme chassis black for painting the engine parts. It sprays well right out of the can, and the cost isn't much more than buying farm paint plus reducer and hardener. Plus the paint is good to 330 F.
We had another couple of days in the 50s and 60s this week, so I got all the engine parts painted before it got cold again. Even in that temperature range, the paint dried pretty quickly. Time to start putting the engine back together!
Afrazer
First Name: David
Last Name: Frazer
Post by Afrazer » Fri Feb 16, 2024 12:32 pm
Took the same opportunity but used rustoleum and a hardener mix brushed on but took a lot longer to dry. Had the kid help on a cracked pan
1925 closed cab TT
1926 two door sedan
