Part I D
fordrelic
First Name: Clay
Last Name: Atkins
* REQUIRED* Type and Year of Model Ts owned: 1921 Roadster
Part I D
Post by fordrelic » Mon Feb 05, 2024 7:32 pm
I received this with some model T parts.
Not sure what it is.
Thanks,
Clay
Re: Part I D
Post by John kuehn » Mon Feb 05, 2024 7:36 pm
Under the engine accessory motor support. Others will comment also.
Re: Part I D
Post by Norman Kling » Mon Feb 05, 2024 8:35 pm
Relieves the stress on the crankcase ears which sometimes break causing the engine to drop. Those are one way of adding extra support.
Re: Part I D
Post by TRDxB2 » Mon Feb 05, 2024 8:43 pm
It is an oil pan support strap (aka belly sling), the purpose was to prevent the crank case arms from breakage. Repro's avaiable at Lang's
https://www.mtfca.com/phpBB3/viewtopic. ... w=previous
You are missing the proper hooks that wrapped around the frame.
fordrelic
First Name: Clay
Last Name: Atkins
Re: Part I D
Post by fordrelic » Mon Feb 05, 2024 8:52 pm
Thanks Guys and great pictures.
Clay
jiminbartow
Last Name: Patrick
Re: Part I D
Post by jiminbartow » Mon Feb 05, 2024 10:11 pm
Over time, the pan ears can get weak, causing the engine to sag. This was designed to relieve the pan ears of much of the weight it supports that will prevent the ears from weakening or breaking. Jim Patrick
tdump
First Name: Mack
Last Name: Cole
Re: Part I D
Post by tdump » Mon Feb 05, 2024 10:20 pm
Does anyone make just the hooks? I have another girdle but no hooks.I have 1 on both my trucks and would like to put the I have left on the speedster,but no hooks. :cry:
Re: Part I D
Post by TRDxB2 » Mon Feb 05, 2024 11:06 pm
Call Lang's if someone is make repro's then they the could get hooks
NY John T
Last Name: Killelea
Re: Part I D
Post by NY John T » Tue Feb 06, 2024 9:22 am
Should not be too hard to fabricate
Re: Part I D
Post by John kuehn » Tue Feb 06, 2024 9:34 am
I agree with NY JohnT
I don’t have any pics of the hooks to post but those aren’t hard to copy and fabricate.
Ed Fuller
First Name: Ed
Last Name: Fuller
Board Member Since: 2012
Re: Part I D
Post by Ed Fuller » Tue Feb 06, 2024 6:18 pm
The one hook that you do have is a correct hook. It is the earlier version that was made by the manufacturer. It has been my understanding that the manufacturer switched from the "strap" version to the "forked" version of the hook when Ford began using the diagonal support straps that bolted to the back of the block and went down to the pan mounting ears.
Here is an older forum post about the supports including some original ads.
