WTB?: Right hand drive Coupe
jaybee47
Topic author - Posts: 356
- First Name: jay
- Last Name: bolante
- * REQUIRED* Type and Year of Model Ts owned: 1922 Runabout
What might be the availability and probability of purchasing a right hand drive Model T Coupe 1920 and earlier? Any leads to suggest?
- Last Name: House
Re: Right hand drive Coupe
Yes. Let me suggest you title this ad: ‘WTB Right Hand Drive Coupe’….
jaybee47
- First Name: jay
Re: WTB?: Right hand drive Coupe
OK. I did. Thank you.
You could also buy the parts and convert one. Might be easier to do it that way.
Very few Ford bodied cars came to Australia due to high import tariffs on fully imported cars, so they are even scarce over here.
Conversion of a LHD car would require;
Hogshead, emergency brake shaft and handle, handbrake quadrant, lower steering bracket, an exhaust pipe, different battery cables, battery cable support arm, carburetor throttle arm, throttle linkage, dashboard, firewall, replacement floorboards etc. You could modify the steering column rods on LHD column to work on a RHD car.
- Last Name: Hatch
You can sometimes find them in Canada.
Have not seen one for sale in a while.
