Front pan mount
Topic author - Posts: 3818
- First Name: Tom
- Last Name: Rootlieb
Front pan mount
I need the piece that lays into the front spring mount and the hand crank passes thru it. It is a casting riveted to the nose of the pan. It can be broken. Doesn’t matter what year. Also need a set of 11-12 hub caps. Nasty and tarnished please. Thanks.
FATMAN
- First Name: ROBERT
- Last Name: BERGSTADT
Re: Front pan mount
Are you talking about the support that rivets to the pan, if so I have some,Bob
- First Name: Tom
Re: Front pan mount
This is what I’m looking for.
Karl Von Neumann
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
Re: Front pan mount
There's 2 different styles you might want to specify
- First Name: Tom
Re: Front pan mount
In my first post, I said it doesn’t matter what year. So to be clear it makes no difference if it is for an early narrow nose pan or the latter pug nose pan. Either one will work. Thanks Tom
Re: Front pan mount
I sent an eMail and also a PM with Pictures
Just realized that your looking fo imperfect 11-12 hub caps. think i have 3 or 4. will check tuesday
