Light Muncie - Gears look good with normal wear. Everything spins nice. Under-Direct-Over-Reverse. Roughly 1.78:1 U, 1:1 D, and 0.73:1 O. Were used in Ts and TTs. I don't have the couplers. $325
Heavy Case Muncie (painted one) - Gears look very, very good with exception of underdrive gear on lower shaft, which has 4-5 teeth in a row damaged. Everything spins nice. Under-Direct-Over-Reverse. Roughly 2:1 U, 1:1 D, and 0.73:1 O. Were used in Ts and TTs. I don't have the couplers. $250
Pickup in Kansas City metro area or free delivery to Chickasha. Happy to answer any questions I can. Thanks!
Auxiliary Transmissions - Light Muncie and Heavy Muncie
Topic author - Posts: 381
- First Name: Nikolaus
- Last Name: Martin
Re: Auxiliary Transmissions - Light Muncie and Heavy Muncie
Back to the top
- Last Name: Martin
Back to the top
