Pedal clamp
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Pedal clamp
Post by Rich P. Bingham » Tue Feb 20, 2024 11:20 am
It isn't often we have to pull the hogshead, most owners dread it. One of the difficulties is having pedals flopping all around while you're trying to wrestle the cover into place. I saw this suggestion for a clamp to hold pedals firm against the ramps several years ago. On my current overhaul I've had plenty of time, so I made this one, and was surprised how easy it was to make. Well worth the time invested !
Get a horse !
Re: Pedal clamp
Post by Rich Eagle » Tue Feb 20, 2024 12:31 pm
Nice work! I like it.
A great idea.
Re: Pedal clamp
Post by Norman Kling » Tue Feb 20, 2024 12:43 pm
Looks like a good idea. On the left hand drive cars like we use in U.S.A. I remove the brake and reverse pedals and the spring from the low pedal. That leaves only one pedal of concern and also the clutch mechanism.
Re: Pedal clamp
Post by Allan » Tue Feb 20, 2024 5:32 pm
With that tool, the internal adjusting washers/nuts/springs could be fitted to the shafts before fitting the cover. Then you have no chance of dropping stuff into the abyss. great idea.
On our RHD cars there is only one internal adjuster, on the first gear band. When I fit the cover, the band ears are wired to the gap available to accept the pedal spring. This is also done on the first gear pedal, with the nut, wsher and spring already in place.
Ed Fuller
First Name: Ed
Last Name: Fuller
Board Member Since: 2012
Re: Pedal clamp
Post by Ed Fuller » Tue Feb 20, 2024 5:43 pm
Nice work!
Here is a period version that came with the band spring compressor tool. When used together they make hogshead installation a lot easier. I just wish I could find one for a ‘26-‘27 style hogshead.
