Lee Thevent speedster plans ? missing parking brake hole placement
jbdairy03
First Name: Jay
Last Name: boldt
* REQUIRED* Type and Year of Model Ts owned: 1
Post by jbdairy03 » Thu Feb 22, 2024 2:43 pm
Hello
checking if anyone that built a speedster body from the Lee Thevent plans Looking for the hole size and placement in the body for the parking brake ?
I can do it with Measuring and math but figured why reinvent the wheel if someone can pic or has measured what they did. it is not mentioned anywhere in the plans. He also has plans on making wood fenders ? wouldn't mind trying just to see how they look but not sure if want to go through the work if others have tried and didn't turn out as well as thought or rounded wood seats for that matter ?
Re: Lee Thevent speedster plans ? missing parking brake hole placement
Post by TRDxB2 » Thu Feb 22, 2024 6:40 pm
Hello
If this is the Lee Thevenet speedster body you are referring to then
I found this should work
How to make wood fenders https://www.horselesscarriagereplicas.c ... et_Jan.pdf
jbdairy03
First Name: Jay
Last Name: boldt
Post by jbdairy03 » Fri Feb 23, 2024 10:42 am
Thank You !
That was what I was looking for !
azmhall
Last Name: Hall
* REQUIRED* Type and Year of Model Ts owned: 1293 Touring, 1925 Touring
Post by azmhall » Thu Nov 21, 2024 11:43 am
You're much further ahead than me. I am curious if you or anyone else on the boards have built the Lee Thevant body and tried using original style steel fenders? Asking because I have a set that I salvaged from a horribly misused body, but I "think" they could work on the speedster with some selective modification.
jbdairy03
First Name: Jay
Last Name: boldt
Post by jbdairy03 » Fri Nov 22, 2024 10:58 am
Unfortunately my project was put on hold during the summer, but if you do a google Search for speedster there are some with fenders I do not think his body plan would interfere with any fender attachment
