cast iron intake
Joe Bell
First Name: Joe
Last Name: Bell
cast iron intake
Post by Joe Bell » Wed May 29, 2019 7:11 pm
I have a cast iron intake with a huge hole like the aluminum ones have in them, It is a first for me, it has some numbers cast in it also like the aluminum ones have.
Hap_Tucker
First Name: Hap
Last Name: Tucker
Re: cast iron intake
Post by Hap_Tucker » Wed May 29, 2019 8:30 pm
Joe,
Not sure if you were asking if that was normal or if you had a different question.
But at: http://www.mtfca.com/encyclo/I-O.htm#man
Under manifolds Bruce has:
1911-1913
Intake manifold changed to straighter aluminum type.
1913-1914
Intake was the same pattern as 1912 but was now made of cast iron (as per letter dated December 19, 1912).
Note the MTFCI 7th edition judging guidelines would put that change from aluminum to cast iron around Oct 1913. So yes, Ford changed from aluminum to cast iron and used a similar design.
Respectfully submitted,
Hap l9l5 cut off
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Thu May 30, 2019 7:25 am
Hap, This one has the intake hole that is large enough to get your thumb in instead of the index finger, like the early aluminum ones, will see if I can get some numbers off of it for exact year. Thanks, this one is a first for me on the cast ones.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Thu May 30, 2019 8:11 am
I went out and blasted it, numbers on it are A T512 B 4 I am not a computer guy so it is tuff for me to find things on these things. Thanks on any help. Joe
Post by Allan » Thu May 30, 2019 8:29 am
Joe, they are really good property. I have two in use, one with a straight bore Holley NH on my tourer. The other one on my roadster has a Stromberg OF. They sure are better than the stranglers used later on. Leastways, that is what I tell myself. The tourer setup yielded 2 extra horsepower on the dyno. How much of that was carburetor or manifold I don't know.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Thu May 30, 2019 9:10 pm
What year? 14 ish? late
BHarper
First Name: Bill
Last Name: Harper
* REQUIRED* Type and Year of Model Ts owned: '14 Touring, '20 TT Farm Truck, '24 TT Depot Hack, '24 Coupe, and a 1914 Metz Model 22 Torpedo Runabout
Post by BHarper » Fri May 31, 2019 10:46 am
Hi Joe,
Mine has the numbers " A T612 B 4 " and are on the early cast iron intake manifolds. As I understand it, Ford used the same mold for the first iron manifolds as they had been using for the aluminum manifolds. I will be installing this one on my Feb/March '14 touring
Someone added a priming cup.
Good luck with your project, Bill
Bill Harper
Keene, New Hampshire
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Fri May 31, 2019 10:05 pm
Thanks Bill, That is what I was thinking they had done also but needed the second on it, sure looked like the aluminum but it was cast, did not know if it was a repop or original.
Moxie26
Last Name: Jablonski
Post by Moxie26 » Tue Jun 04, 2019 2:47 pm
Joe, you will be very satisfied with that larger cast iron intake. Had one on my car similar setup is mentioned with a straight through Holly, foolishly changed to a regular issue or later issue cast iron and even though it ran a little bit smoother I was not happy with the lesser top end and responsiveness
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Thu Jun 06, 2019 12:21 am
I've got one, too. Was going to use it, but wanted a hole in the manifold to mount a Wolf whistle (of all things) and I didn't want to ruin a rare manifold, so I "hogged out" a dime a dozen standard manifold.
