R G Reeder Heads
J1MGOLDEN
Last Name: Golden
R G Reeder Heads
Post by J1MGOLDEN » Sun Mar 03, 2024 3:49 pm
Does anyone still use an R G Reeder Aluminum Head?
I have been helping a friend to get a Model T running right that he inherited, and it has everything no one needs, especially a 12 Volt system, for the distributor, and R G Reader kind of ruff head.
The Mag coil ring was removed and the magnets were removed from the flywheel.
I like to keep the engine, in good condition, the way Henry Ford built it.
Re: R G Reeder Heads
Post by Jerry VanOoteghem » Sun Mar 03, 2024 3:53 pm
I use one one my Speedster. I'm sure there are a lot of them out there.
KeithG
First Name: Keith
Last Name: Gumbinger
Post by KeithG » Sun Mar 03, 2024 3:58 pm
I have a Reeder head on my '14 Touring and it works great. It also has great compression.
I bought it in 2006, have not drilled any extra holes in it & have not had it resurfaced. This car is a hand crank only and usually starts on the 2nd or 3rd pull. When cranking it you can REALLY tell it has lots of compression. I'm happy with it!!!
Keith
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Sun Mar 03, 2024 5:26 pm
I have Reeder heads on my 1915 and 1911.
I am pleased with both of them.
If you are thinking about sending the head down the road, please let me know.
Keith
Post by TRDxB2 » Sun Mar 03, 2024 9:27 pm
Well if your looking to get ride of the head, send it my way - what head would you like back?
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Mon Mar 04, 2024 9:21 am
The head is on a friend's 1924 Model T engine that I am helping get running well.
The engine starts rather quick and easy, so the head does not seem to be a problem.
With these comments and a few others I have recently received, it looks like the head will stay where it is now.
One other interesting comment is that Ralph G Reeder and Ralph Zajicek were both from Dickerson, Texas.
They both went cross country in R, G.s 1920 closed T.
They both were selling aluminum heads about that time.
Did that tour ruin a good friendship?
bill_severn
First Name: Bill
Last Name: Severn
* REQUIRED* Type and Year of Model Ts owned: 1916 Touring, 1921 Center Door Sedan
Post by bill_severn » Mon Mar 04, 2024 2:14 pm
I just bought a Reeder head. Plan to put it on my 16 Touring.
Are there any issues when installing this head? Do you use high head bolts? Any special considerations?
Bill
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Mon Mar 04, 2024 7:23 pm
Reeder Made a high head and a low head.
You have to know which one you have to determine the bolt length required.
You can buy an anode to reduce the dissimilar metal corrosion problem.
Last Name: House
Post by George House » Tue Mar 05, 2024 6:37 am
Another interesting tidbit about that centerdoor in the picture - Ralph air conditioned it 😳
Bruce Compton
First Name: Bruce
Last Name: Compton
* REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Post by Bruce Compton » Sat Mar 09, 2024 7:30 pm
I'm considering installing a Reeder head on my crank-start only '14. Being 80+, will I have a hard time cranking it???? , or is it that much better than the stock original low head.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Sat Mar 09, 2024 8:23 pm
Bruce,
You will be able to feel some difference in cranking, but not enough to make you think you made a bad decision. As long as you coils are rebuilt and calibrated, and your carburetor is good and dialed-in, the increased compression should make it start easier. If you are not happy with your Reeder head, let me know!
Keith
Bruce Compton
First Name: Bruce
Last Name: Compton
Post by Bruce Compton » Sun Mar 10, 2024 3:51 pm
Thanks Keith. Going to give it a try.
