WTB Raydex Light diffuser
WorldChamp1914
Topic author - Posts: 420
- First Name: Gary
- Last Name: Hagen
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring and a 1921 Sightseeing Bus.See SF On a Dime
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
Re: WTB Raydex Light diffuser
Hard to find ?
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
Any out there?
Video of what they do https://m.facebook.com/FentonHistoryCen ... 553574209/
Check this out pair went unsold uin Victoria https://online.doningtonauctions.com.au ... -diffusers
These were use to cutoff light that blinded oncoming drivers as well. Shade is green
- Attachments
- MB 8. 1-4a.JPG (61.25 KiB) Viewed 1259 times
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
Thanks for that post….interesting.
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
8 1/4 Macbeth…..any out there for sale?
Yes the ones above are mine and for sale
They are the early flat style so the eyebrow is flat not bulged out. early lens are round & use a different rim style clips than H lens. have them too
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
I have a 1921 T
The differences in electric headlight buckets are how they are mounted on the car: fork, fender support arm (subtle bracket differences), or fender brace. Also the adjustment position screw 6 vs 9 o'clock. Rim finish 1915 Brass, then Black then Nickle (1926-27). The lens changes from round to H pattern caused the clips inside the rims to change, but the rivets to secure the rime to headlight bucket did not change for the Black & Nickle buckets.
From the MTFCA Encyclopedia Green Visor on 1921 replaced the clear round lens- What lens do you have clear or fluted? --
Rim Clips - some use H style clips on round glass
