Holley G carb float… cork or modern replacement?
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Wed Mar 13, 2024 1:16 pm
I’m rebuilding brass Holley G for my ‘14 touring. The carb I’m building has an OK cork float that needs sealed, but I thought I would replace it with the modern material float that’s available. First, the new float is about 3/16” thicker than the cork float. Is this to compensate for the flotation density between the two materials? Second, if you had your choice, would you use the new float or revive the old cork float? If using the cork, what’s best to seal it with?
Kurt in NJ
First Name: Kurt
Last Name: Fehr
* REQUIRED* Type and Year of Model Ts owned: 1917 touring
Re: Holley G carb float… cork or modern replacement?
Post by Kurt in NJ » Wed Mar 13, 2024 1:19 pm
I sanded the modern float to match the size of the original, working perfectly
Post by speedytinc » Wed Mar 13, 2024 1:22 pm
I would use the modern float material. As far as buoyancy differences, it don't matter on a G. You will set the fuel level wet in the jet bowl.
I have used "line-a-tank" Green & white label to seal cork floats.
dykker5502
First Name: Michael
Last Name: Deichmann
Post by dykker5502 » Wed Mar 13, 2024 1:38 pm
Cork is treated with shellac which are dissolved by ethanol/alcohol.
Ford Model T 1914 Touring
jpcouture
First Name: Jay
Last Name: Couture
Post by jpcouture » Wed Mar 20, 2024 11:06 pm
I also use a modern float sanded down to original thickness as recommended by others on the forum The material is soft and easy to work with.
