FS ACCESSORY OIL BREATHER CAP (SOLD)
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Thu Mar 14, 2024 5:39 pm
Accessory flip-top oil breather cap. Cast aluminum. Price is $75.00 with free domestic shipping. Mark Chaffin (951) 805-0928
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: FS ACCESSORY OIL BREATHER CAP
Post by Dan McEachern » Thu Mar 14, 2024 6:30 pm
Mark- does this fit the early or late timing cover? I think there is a difference.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Thu Mar 14, 2024 7:07 pm
Smaller of the two. Height wise.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Thu Mar 14, 2024 8:28 pm
I didn't realize there was a difference. I'd better check my APCO oil filler. If it doesn't fit a late (26-27) timing cover, I'll have one for sale.
Dan McEachern
First Name: DAN
Post by Dan McEachern » Thu Mar 14, 2024 8:39 pm
On the early cover, the 3/8 bolt pretty much goes thru the center of the fill hole. On the later generator covers, that bolt is offset to the inner edge of the fill hole. I'm not sure what Mark is referring to above. The fill holes are pretty much the same size regardless of gen or non-gen cover............
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Thu Mar 14, 2024 10:41 pm
This is a Tim Morsher cast reproduction. I believe it may fit either style.
Mark Chaffin
Last Name: Chaffin
Re: FS ACCESSORY OIL BREATHER CAP (SOLD)
Post by Mark Chaffin » Mon Mar 18, 2024 8:52 pm
Sold to Shannon. Thank you
DavidGMeier
First Name: David
Last Name: Meier
* REQUIRED* Type and Year of Model Ts owned: 1919 Model T Touring
Post by DavidGMeier » Sat Sep 06, 2025 1:12 pm
so, this replaces the current oil filler cap? Do you know if it would be for a 1919 Model T Touring?
